Problems with the sound on your TV? In our help articles you'll find tips on how to solve these problems.
The broadcast is interrupted on satellite TV
SCART connection
HDMI connection
If the problem isn't solved, try reversing the ends of the SCART/HDMI cable or replacing the cable with another one.
If the signal strength is less than 58 dBV (on the mainland) or 60 dBV (on the islands) and the weather is bad, you should wait; if the problem persists, contact customer Support(see the plan) when you are near your MEOBox (see plan), or contact customer Support atMEO Empresas (see plan).
If the problem persists, contact customer Support(see plan), or customer Support atMEO Empresas (see plan).
The picture doesn't fit on the Satellite TV screen
Adjust the screen format on your MEOBox Pace (Zapper 3, Zapper 4, DVR3, or DVR 4 models)
Adjusting the Screen Format on a Samsung MEOBox (Full HD)
Satellite TV has no sound or poor sound quality
The tests below aim to help solve the problem by carrying out simple tests.
If there is no sound or the sound quality is poor in only one channel:
Note: PACE MEOBoxes have 2 SCART ports; in these cases, plug the cable into the bottom port (preferably)
If there is no sound or the sound quality is poor on all channels:
If the signal strength is less than 58 dBµV (on the mainland) or 60 dBµV (on the islands) and the weather is bad, you should wait; if the problem persists, contact customer Support(see the plan) when you are near your MEOBox (see plan), or contact customer Support atMEO Empresas (see plan).
If the power is lower than the reference values in the table and you cannot view channel 202:
Restore the MEOBox to its original settings:
