SITUATION 1: MEOBox is without lights
Please check:
1. If the MEOBox ON/OFF button is turned on (press it to the ON position)
2. If the transformer is correctly connected to the MEOBox and the socket
3. Test in another socket or without the power strip if it is in use.
If you still don't get an image when you connect the MEOBox, check it:
1. Whether the TV is set to the correct HDMI channel
2. If the HDMI or Scart cable is connected correctly
Note: we recommend that the connection between the MEOBox Android and the TV is made using an HBMI 2.0 cable.
SITUATION 2: MEOBox has lights on
If you are connected via WiFi, check that connection as well:
1. go to
Settings > Network and Internet > Connected to WiFi network
3. Reconnect to your home WiFi.
If you're connected by ethernet cable, check that the cable is correctly placed in the box and in the router.
If the problem persists, close the appby going to Settings > Apps > MEO > Force Stop. Then reopen the MEO app.
The first time you use it, see how to
install and configure the MEOBox Android TV 4K. You can also consult the
user guide.
SITUATION 3: When I open the MEO app, the screen goes blank for a few seconds and then returns to the menu Android
To resolve this issue, go to the operating system menu atAndroid (outside the MEO app) and remove the app's updates.
Go to Settings > Apps > APP > MEO > Uninstall Updates
After this step, we recommend that you go to the Google Play Store and update to the latest version.
