Skip to content
Problems with text/MMS - MEO Help
Can't send or receive text or MMS? Here's how to solve it.
More help?
my MEO App
my MEO
my MEO App
Digital assistant
Digital assistant
Digital assistant
MEO Forum
MEO Forum
MEO Forum
MEO Stores
MEO Stores
MEO Stores
Video Tutorials
support lines
Problems text/MMS
  • I can't send it text
    If you're having trouble sending text, follow these steps:
    1. Check if your card has sufficient balance or available credit limit for the desired " text " by dialing *#123# and pressing the call button.
    2. Check to see if you have a network connection
    3. Check to see if the message center is set up correctly (+351 962 100 000)
    4. Send an e text with *not#message text and check to see if you receive a delivery confirmation from text
    5. Try the card at another mobile phone – if it works there, the problem is with your device
    If you are rep text ing a message from another carrier, create a new message and send it.
    If the problem continues:
    • Contact customer Support (see plan) or customer Support atMEO Empresas (see plan).
    • Send the equipment in for repair:
      • Ask a courier to pick up the equipment
      • Send by mail
      • Go to a MEO store with technical assistance
  • I can't get paid text
    If you are having problems receiving text, follow these steps:
    1. Check if you have a network
    2. Make sure that the number sending you text is not on your device's spam/ rejection list:
      • Android (may vary depending on the manufacturer and version of Android): Calls > Three dots icon (top right) > Settings > Reject list > Settings wheel icon (top right) > Block list
      • iPhone: Settings > Phone > Blocked Contacts
      • Windows: Settings > System > Call filter + text
    3. Check to see if the memory on your SIM is full—if it is, delete some messages
    4. Try the SIM card on another mobile phone — if it works, the problem is with your device
    • Contact customer Support (see plan) or MEO Empresas customer Support (see plan).
      • Send by mail
  • I can't send or receive MMS messages
    If you are having problems sending or receiving MMS, follow these steps:
    1. Confirm that your MMS service is active by calling Support at MEO customer or Support at MEO Empresas customer .
    2. Check that you have mobile data connected
    3. Validate that you have the MMS service configured
      • Android (may vary depending on the manufacturer and version of Android): Go to Settings > Mobile network > Mobile data > Access point names (APN)
      • iPhone: Settings > Mobile data > Mobile data network
    4. Try the SIM card SIM mobile phone if it works, the problem is with your device.
      • Send by mail
