The kit is an intelligent security system that you can easily install yourself, without the need for specialized technicians or advanced technical knowledge to configure the alarms.
What's included:
An Ajax Hub2 security control panel
A motion detector with image capture
A door/window opening sensor
A command
All these devices communicate wirelessly using Jeweller technology, ensuring fast and secure signal transmission, but you can activate and deactivate the alarm manually using a keypad, remote control or panic button.
Through the Ajax Security System app, available for Android and iOS, you can monitor your home in real time and receive notifications on your mobile phone whenever there is suspicious activity. App updates are made automatically to improve the system's performance and security. This app also allows you to authorize multiple users to access the system.
All the equipment is protected against interference, signal blocking attempts and physical sabotage, and the motion sensors have technology that prevents false alarms by ignoring animals up to a certain weight.
The system is compatible with automation devices such as smart locks, lights and security cameras, allowing you to complete the solution according to your needs.
If you move house, you can reinstall the system at your new address at no extra cost.
The purchase of this Kit does not require a monthly subscription or loyalty contracts with security companies, since the Kit is not connected to an Alarm Receiving Center (ARC) and works independently.
The solution can be purchased with a one-time payment or in installments for eligiblecustomers .
