WiFi Calling is a service that allows you to make or receive calls from your smartphone over WiFi. This means that if you are in a place where the mobile network is weak or non-existent, but you have access to a WiFi network, you can make better quality voice calls over WiFi.
In order to use the service you must:
- Having a compatible smartphone
- Have the latest version of the software installed on your smartphone
- Have VoLTE (Voice over 4G/5G networks) enabled. To enable it, send a fre text text message with the word "Volte"to 16200( customers MEO, and MOCHE only),16205 (customers UZO), or 16206 ( customer MEO Empresas )
- Make sure Wi-Fi Calling is enabled on your smartphone. See below for instructions on how to enable it
- WiFi coverage
Calls made over Wi-Fi are billed according to your mobile plan plan, just like any other call made on the mobile network, whether they are made domestically or abroad. If you have minutes included in your plan plan, they will be deducted from that allowance (as if you were making a call on the domestic mobile network). If you do not have any minutes available in your plan plan, the rate for calls outside the allowance will apply.
After activating the service on your smartphone, when you are connected to a WiFi network and have poor mobile network coverage, voice calls will automatically switch to the WiFi network.
Operation and recommendations for use WiFi calls
- When you are making a WiFi call and go to an area without WiFi coverage, the call will automatically switch to the 4G/5G mobile network. However, if the mobile network is 2G/3G, calls over WiFi are automatically terminated and you have to make a new call. The same happens if you switch from the mobile network to the WiFi network.
- On Android devices, we recommend that you keep the "Preferred Mobile Network" option, which guarantees the best quality for each call by automatically selecting the most suitable network at the time (4G/5G mobile or WiFi).
Activate the WiFi Calling feature on mobile phones Android:
The steps for activating WiFi Calling may differ depending on the brand of your smartphone. These steps refer to a mobile phone Samsung.
Activate the WiFi Calling feature on iOS mobile phones :
You can also enable this feature by going toSettings > Cellular > Wi-Fi Calling > ENABLE on this iPhone.
