The way to activate a replacement MEO SIM card on how you made your request. See all the available options below and choose the one that corresponds to your request.
If you requested a duplicate copy of "eSIM " to be sent by email, simply open the email you received from MEO and follow the installation instructions provided.
Once the process is complete, your eSIM ready to use.
Activate yourSIM, eSIM , or MultiSIM card by phone
If you prefer, or if you are using a physical “ SIM ” card, you can activate your duplicate card by calling
Customer Support at customer(see the
plan). The call must be made using your old SIM card, which will be replaced by the new duplicate card.
To complete the activation, have the new ICCID number (the last 10 digits of the card) and the PIN handy.
SIM Card ordered at a MEO store
When duplicate SIM Card SIM is ordered directly from a MEO store, activation is immediate.
PIN , and PUK codes for the new card
Whenever a replacement card is issued, the , and PUK codes are updated. On physical PIN
cardsSIM, the new codes are located in the gray area; simply scratch them off. For digital cardseSIM , you will receive an email indicating that you can view the , and PUK codes in PIN the app my MEO.
By default, the eSIM PIN eSIM disabled, but you can enable it to increase security when using the service.
